Home » Sponsored » Pi Speakers » My 4 Pi Build
Re: My 4 Pi Build [message #97180 is a reply to message #97179] Fri, 10 November 2023 14:21 Go to previous messageGo to previous message
The compression driver mounts onto the horn with a couple of 1/4-20 bolts that are spaced 3" apart. Each mounting bolt is 1-1/2" from the center. Some call this the "standard two-hole mounting pattern."
In the case of the B&C DE-250, you could use 1/4-20 bolts but they include a couple of studs and nuts with that compression driver so I personally always use 'em.
Previous Topic: 2Pi Towers - new build from Poland
Next Topic: Request for 4 Pi Plans
Current Time: Mon Nov 23 12:40:15 CST 2026
