Home » Audio » Thermionic Emissions » Seeking info - Antique Sound Usa ASUSA K2003 amp
Re: Seeking info - Antique Sound Usa ASUSA K2003 amp [message #97034 is a reply to message #97031] Thu, 28 September 2023 20:45 Go to previous message
Suhomeso is currently offline  Suhomeso
Thanks for the responses. I've found suitable socket replacements, I just wanted the schematic to double check the previous work, since these came in kit form. The really loose right channel is distorted and does clean up a bit when the tube is manipulated for better connectivity.
I've tried the things on your socket list already. Nothing has helped so far, the socket is really worn out. I have tube savers coming tomorrow to try, that'll be my last ditch effort. Tubes pins are clean/ brand new. Sockets cleaned with contact cleaner and look brand new on the surface. They're just way too loose, I can't get them tight enough with any pin, pick, or object, unfortunately.
Previous Topic: EL34 tubes - RFT vs EI Yugoslavia
Next Topic: Optimal settings for 6P3S-E output tubes in Leben CS-600(X)s
Current Time: Sat Nov 07 13:10:14 CST 2026
