Home » Audio » Thermionic Emissions » Source loop
Re: Source loop [message #96999 is a reply to message #96998] Mon, 18 September 2023 06:22 Go to previous messageGo to previous message
I'm trying to understand some of the terminology Bruce. My knowledge of electronics is rather thin. The Aphex unit has a switch to accommodate consumer level gear if that's part of what your conveying. My original thought was kind of like how I'd used it prior which was from a stand alone phono into the Aphex then into any input of the preamp. Just that this preamp now has the internal RIAA circuit built in, so I'd wondered if an added output would function about the same as how I'd utilized it before. The two way on-on switch just allowing the preamp to function somewhat as is stock. Hope I make sense. I think you for your skilled advice.
Previous Topic: Optimal settings for 6P3S-E output tubes in Leben CS-600(X)s
Next Topic: Update on Previous Info on Oddwatt Amp issue
Current Time: Sat Nov 07 13:10:33 CST 2026
