Home » Audio » Thermionic Emissions » Source loop
Re: Source loop [message #96998 is a reply to message #96994] Sun, 17 September 2023 21:52 Go to previous messageGo to previous message
Hi Rusty, It will likely work OK. My major concern is if there is a serious impedance mismatch that could mess up the sound. It could be too high feeding into a low Z input or the other way around. The first would likely cause serious loss of high freqs, the other loss of bass. There could also be an issue with differing signal strength. One very loud the other not so. Yes a pop could occur if any of the outputs has a coupling capacitor that gets slightly charged up above zero on the output side. Most designs use a sort of bleeder resistor (1meg seems common) to eliminate this problem. Anyhow worth a try. Let us know how it goes.
Previous Topic: Optimal settings for 6P3S-E output tubes in Leben CS-600(X)s
Next Topic: Update on Previous Info on Oddwatt Amp issue
Current Time: Sat Nov 07 13:10:27 CST 2026
