Home » Audio » Thermionic Emissions » Interpreting tube setup in a Leben CS-600
Re: Interpreting tube setup in a Leben CS-600 [message #96628 is a reply to message #96620] Thu, 13 April 2023 22:00 Go to previous messageGo to previous message
Hi, That is a good question and not clear from the schematic. But since there are two tubes per channel I would expect the voltage amp stage to use the low power portions of each tube and the inverter/driver to use the high power sections. According to my RCA book the low power section if pins 6,7,8 and the high power one 1, 3 and 9. heaters are 4 and 5. I hope this helps. let us know.
Previous Topic: Leben CS600X - Class AB or pure class A?
Next Topic: A fix for Oddwatt type amps running on low AC mains voltage
Current Time: Thu Nov 05 12:42:35 CST 2026
