Home » Sponsored » Pi Speakers » Am I in the Right Place? (JBL 2226HPL)
Re: Am I in the Right Place? [message #96606 is a reply to message #96590] Thu, 06 April 2023 17:33 Go to previous messageGo to previous message
hazmoment is currently offline  hazmoment
I checked the JBL 2226 Datasheet and they recommend a 4cu ft enclosure tuned to 40Hz for a single one of these drivers. Any advantage to go either side of that, size wise? you mentioned between 2ft and 5ft. Size is not a problem-
I can go as big as I have to because space isn't a problem. But what would be the pro's and con's of going for a 5ft?
Where should I begin on the design of this enclosure. How can I "tune" the enclosure? Is it by correctly designing and implementing the Port(s)? I have downloaded WinISD, but not exactly sure what Im doing with it. I do operate a CNC machine here so I was thinking to make a nice flared port to compliment the matching Horns I previously posted.
Im thinking HPL or Birch Ply for the build. But dont want to waste my time and money on a build that isnt correctly designed. I have been trauling the web for some time now, but so many different designs, drivers, concepts, ideas, I have lost track of what the main objective is for building a box. You say I should avoid standing waves. I presume WinISD would show this if there are certain peaks in simulated frequency response when modelling? If so, how am I avoiding them? just changing the size? or adding damping materials?
Previous Topic: 2023 4pi build
Next Topic: Four Pi Build - recessed drivers
Current Time: Mon Nov 09 18:15:06 CST 2026
