Home » Audio » Thermionic Emissions » Leben CS600X - Class AB or pure class A?
Re: Leben CS600X - Class AB or pure class A? [message #96575 is a reply to message #96551] Tue, 28 March 2023 10:48 Go to previous messageGo to previous message
kasperbergholt is currently offline  kasperbergholt
gofar99 wrote on Fri, 24 March 2023 21:56
Hi, just FYI...in class A push pull a pair of EL84s at 225-275 V B+ will deliver about 5 watts in Ultra linear mode and about 6.5 watts in pentode mode. Triode mode is just about 4 watts. All at less than around 1% THD+N without negative feed back. Also FYI all my designs for amps (4 watts to 40 watts) are a forced class A U/L mode. Inefficient for sure, but really nice sound. Well designed class AB amps can sound really nice as well, but I have seen none without negative feedback that do so. IMO NFB alters the sound...in hard to define ways and is a cause for considerable consternation in the audio field. Lots of arguments on it. A SE amp can work either way...but then they are all class A.
Thank you for the explanations.
My previous amplifier was an Audio Note P2SE (single ended-typology) and zero negative feedback.
The tonality is very close to the Leben's, I think, but the Leben has got 'more punch'; that said, I know it's very difficult to do sequential listening comparisons without being able to swithc between to.
Previous Topic: Dating of 4 6CS7 (NOS) tubes from Sylvania
Next Topic: Interpreting tube setup in a Leben CS-600
Current Time: Fri Nov 13 09:06:01 CST 2026
