Home » Sponsored » Pi Speakers » Subs for floorstander and corner horns
Re: Subs for floorstander and corner horns [message #96492 is a reply to message #96490] Wed, 08 March 2023 13:20 Go to previous messageGo to previous message
Here you go:
That shows overall diameter and baffle hole diameter, which can be used to determine the width of the routed groove. Depth, on the other hand, isn't listed there. But the depth should be to 5/8" to 3/4" to make the driver appear flush.
The rubber surround actually protrudes past the front gasket, even when the driver is at rest. So to make the gasket flush, you would want a 5/8" depth recess. The get the surround to be flush, you'd need a little more depth, about 3/4".
Previous Topic: Pi Three and Pi Four Speaker Plans?
Next Topic: Pi3 vs Pi4
Current Time: Mon Nov 09 18:21:28 CST 2026
