Home » Audio » Thermionic Emissions » Class A, AB1, B, C Operation/Modes (How Class A, AB1, B, C Modes Work and Their Strengths and Weaknesses)
| Re: Class A, AB1, B, C Operation/Modes [message #96354 is a reply to message #96353] |
Thu, 09 February 2023 21:35   |
positron
Messages: 164 Registered: May 2020
Master |
gofar99 wrote on Thu, 09 February 2023 21:01Hi, MLs act like huge capacitors. They go from just over 4 ohms at low frequencies to 1 ohm at 20K. The slope of impedance can give many amps fits. It was why I added 3 db of frequency limited NFB to my amps. I figured they were about as tough a load as anything anyone would use. (some crossovers might be worse though) I have not had any misbehave without it...but testing shows a strong resonance point in most of the amps at about 70-85KHZ. So I start the slope at about 25-30K and it insures stability no matter what the amp sees on the output side. I have tested all of the various sizes with and without the NFB and have not been able to get any to mess up...still a couple of parts is cheap insurance. In the commercial versions and shown on the diy schematics I show NFB defeat switches and most folks can only say that the use of NFB cuts the gain by a few db. No surprise there...but in a blind test can't tell which one is which.
Yes, that is quite a change in load.
After discussing the matter with a Harvard Medical School chair years ago, one item I think we need to be cautious of is blind testing.
There are many confound variables that need to be addressed. Otherwise
the test will always be skewed toward no sonic difference. It then basically becomes a rigged test.
I used to test every day for weeks, months or longer, but addressing confounds. Now I have the ability to hear the change quite easily. I still test every day after a tweak is made, just to be sure though.
cheers and all the best.
pos
By: positron on Sun, 05 February 2023 20:40
By: gofar99 on Mon, 06 February 2023 20:38
By: positron on Tue, 07 February 2023 16:13
By: gofar99 on Tue, 07 February 2023 19:33
By: positron on Tue, 07 February 2023 20:37
By: gofar99 on Thu, 09 February 2023 21:01
By: positron on Thu, 09 February 2023 21:35
By: positron on Tue, 28 February 2023 19:04
By: gofar99 on Wed, 01 March 2023 19:45
By: positron on Sun, 05 March 2023 00:33
By: gofar99 on Sun, 05 March 2023 08:10
By: positron on Mon, 06 March 2023 19:01
By: gofar99 on Tue, 09 May 2023 21:30
By: positron on Tue, 05 September 2023 23:48
By: gofar99 on Fri, 08 September 2023 21:12
By: positron on Thu, 12 October 2023 11:21
By: positron on Fri, 03 November 2023 12:22
By: gofar99 on Fri, 03 November 2023 20:58
By: positron on Sun, 05 November 2023 01:38
By: positron on Thu, 07 December 2023 23:12
By: gofar99 on Mon, 18 December 2023 20:20
By: positron on Tue, 16 January 2024 21:32
By: gofar99 on Wed, 24 January 2024 20:31
Current Time: Wed Oct 28 10:03:48 CDT 2026
