Home » Audio » Thermionic Emissions » New Production Tung Sol 6550, Penta KT88s (Concerning Audio Quality)
Re: New Production Tung Sol 6550, Penta KT88s [message #96292 is a reply to message #96284] Sat, 21 January 2023 18:24 Go to previous messageGo to previous message
Evidently no one uses them?
My testing has found both tubes to be rather thin, anemic sounding compared to JJs and Winged Cs.
So I demagetized both, using my 100 watt soldering gun magnetic field (gun windings), and both tubes became fuller than the JJs and Winged Cs. Quite a sonic change. The new Pentas just slightly fuller than the new Tung Sols.
When the tubes are manufactured, induction heating of the plate removes gases. Evidently, the switch/field is simply flipped, rather than gradual field removal.
So when one purchases a new output tube, what you purchase and hear is not necessarily what the tube sounds like after being demagnetized.
One could probably use a dryer, a motor, anything that produces an AC magnetic field. Simply rotate each tube around the AC device field, and then gradually distance the tube from close to 3 feet or more from the device, and power off the device.
cheers
pos
Previous Topic: 6N11 vs 6922, E88CC, and 6DJ8 tubes
Next Topic: TAD KT88
Current Time: Thu Nov 12 11:14:32 CST 2026
