Home » Audio » Thermionic Emissions » Cleaning Connections on Equipment (How Often Do You Clean your connections?)
Re: Cleaning Connections on Equipment [message #96280 is a reply to message #96233] Tue, 17 January 2023 13:32 Go to previous messageGo to previous message
I have been using spray cleaner that leaves no residue. My tube sockets
are gold plated, which seem to work nicely over the years.
I tried an experiment, some year or more ago, of fastening the speaker
wires to the speaker jacks as an anchor, but soldering a wire directly
from the speaker wires to the crossover, eliminating one physical pressure connection.
It is working fine as I found the bass was more consistent. Maybe my fingers are weak from age, but I found that tightening with a wrench improved the bass tautness, by increasing contact area due to surface irregularities, and is gas tight. (Of course I did not strip the threads.)
Might be something worth trying.
Cheers
pos
Previous Topic: Tung-Sol 7581A vs Tung-Sol 6L6G Big Bottle
Next Topic: Tube amps on PC.
Current Time: Wed Oct 28 09:09:52 CDT 2026
