Home » Audio » Source » Practical limit to tube based phono preamps
Re: Practical limit to tube based phono preamps [message #96271 is a reply to message #96270] Thu, 12 January 2023 21:45 Go to previous messageGo to previous message
Wayne Parham wrote on Wed, 11 January 2023 18:02
Interesting stuff. To me, that's the "holy grail" of tube amps.
Rare indeed is the tube amp that is dead black quiet between musical passages.
I thought I would do a little more research that might help..
The Vishay Z, S102, tx2352 resistors have approximately
10 nano-volts/volt across the resistor, current noise.
Another figure given is -40db. Expensive.
Mills non-inductive wire wounds equal or pretty close. Expensive
Metal films seem to Max out at 200 nanovolts/volt (0,2 microvolts/volt)
I do not know the averge for all metal films. Based on 0,2, that would
be approximately -14db.
Inexpensive.
Metal oxide inexpensive and
finally carbon types inexpensive. I saw figures of 10 microvolts/volt
for carbons.
cheers
pos
Previous Topic: STD 305M with SME Series 3 Arm, Which Protractor
Next Topic: Saved On Vinyl
Current Time: Fri Nov 06 01:06:57 CST 2026
