Home » Audio » Thermionic Emissions » Cleaning Connections on Equipment (How Often Do You Clean your connections?)
Re: Cleaning Connections on Equipment [message #96233 is a reply to message #96231] Thu, 15 December 2022 19:53 Go to previous messageGo to previous message
Hi, I have used deoxit that way as well. It works fine...just don't get it on any painted surfaces as it can damage them. In older RCA jacks you can spray it on a Q tip and swab the holes. It usually works. As a general rule don't use WD40 on anything audio. It tends to leave a residue that will build up over time and cause a problem worse than the one you wanted to cure.
Previous Topic: Tung-Sol 7581A vs Tung-Sol 6L6G Big Bottle
Next Topic: Tube amps on PC.
Current Time: Wed Oct 28 09:09:25 CDT 2026
