Home » Audio » Source » STD 305M with SME Series 3 Arm, Which Protractor (Need protractor to setup SME Arm)
Re: STD 305M with SME Series 3 Arm, Which Protractor [message #96127 is a reply to message #96126] Sun, 30 October 2022 21:55 Go to previous message
Rusty wrote on Sun, 30 October 2022 10:27
I think the 2 point protractor system is common with all the Vinyl Engine protractors. Less distortion. Glad you resolved your dilemma. Time to listen to fine music now.
Thanks Rusty. I ended up moving the SMEIII arm back some when using
the Stevenson protractor, less distortion was clearly noticed. It also
looks closer to others setups I have seen.
Thanks for your help, and others. Much appreciated.
pos
Previous Topic: Belden 8402 cable between turntable & RIAA
Next Topic: Practical limit to tube based phono preamps
Current Time: Fri Nov 06 01:30:41 CST 2026
