Home » Sponsored » Pi Speakers » Kudos to Wayne for the 4pi and 3pi subs!
Re: Kudos to Wayne for the 4pi and 3pi subs! [message #96113 is a reply to message #96112] Sun, 23 October 2022 13:53 Go to previous messageGo to previous message
pjanda1 is currently offline  pjanda1
Thanks! I was conflicted on choosing a finish pattern more typical of modern narrow baffle Scandinavian speakers, especially right now, when classic monitors are back in fashion. But, part of the damage before was because square edges are tough to keep clean on big heavy speakers, especially over soft MDF. And, if you goof up a black bevel, a paint marker will make it fairly invisible.
For those looking to achieve a similar bevel on a budget, it was this cheap table bit run 90 off from what you'd expect and set to not protrude deep enough for the thumbnail: https://www.amazon.com/Yonico-Thumbnail-Handrail-Diameter-13143/
Paul
Previous Topic: Vent size for Theater 4 Pi
Next Topic: Pi 4 plans please
Current Time: Wed Oct 28 10:01:58 CDT 2026
