gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
Hi, I have used a number of different cables and presently I am using Belden 8412 on one turntable (Grado Sonata II cartridge) with the conductors used as balanced mode with the shield only at one end. On the other main turntable I am using Mogami 2534 with the two pairs connected together in a balanced mode going from a Dynavector Karat23MR-RS to the SUTs with only one end of the shield connected to ground. Each arrangement uses two cables from the cartridge to preamp or SUT. I get great sound and no noise from this arrangement. When I used single core cables I always had some hum and noise. Then again I am quite picky about hum and noise and anything that degrades it is unacceptable. Mogami 2552 was nearly as good as the 2534. BTW the Belden is a PITA to work with and get clean terminations because of the fluffy internal insulation.
