Home » Audio » Source » Belden 8402 cable between turntable & RIAA
Re: Belden 8402 cable between turntable & RIAA [message #95849 is a reply to message #95848] Thu, 21 July 2022 10:02 Go to previous messageGo to previous message
I like Mogami cable. I used the W2549 long run cable between my turntable and it's distance to the line preamp because of it's lower capacitance (23pf/ft). It's construction makes for easier soldering than other cable I've used. And it sounds fine to me. But, I'm sure your choice would work fine as well. Cabling other than it's useful characteristics needed for the signal integrity ends there. Nothing exotic or expensive needed for me.
Previous Topic: What happened with wire recorders?
Next Topic: STD 305M with SME Series 3 Arm, Which Protractor
Current Time: Fri Nov 06 01:43:20 CST 2026
