Home » xyzzy » Tower » John Busch
| Re: John Busch [message #95800 is a reply to message #95688] |
Fri, 08 July 2022 10:17   |
Pano
Messages: 17 Registered: May 2010
Chancellor |
Things that might be there.
A list taken from 2018. I did not see any of this in the photos, but I'm pretty sure that much of it is still there. It's a gamble, really. If you want to buy the lot, some of this stuff will be there for sure. There are also items there that John mentioned but that I do not see on the list.
To be clear. This is a guess! Not all of this will be there, and the quantities listed were current ONLY in 2018.
Estimated Quantity Item type Estimated Condition
4 PE BR-1 black. 12 Liter cabinets for 6.5" Woofer woofer NIB
2 Eminence Beta 12" CX woofer. woofer NIB
18 Peerless 6.5" woofer. 835005 woofer NIB
4 Dayton 12" PA woofer. PA310-8. woofer NIB
4 PE Dayton 18" PA woofer. PA-460-8. woofer NIB
12 PE B/O Titan 18" PA woofer PA-1880 woofer NIB
4 PE 180-S 7" woofer 295-364. NOS woofer NOS
4 Peerless 7" Woofer. CSC-X850122. NOS woofer NOS
8 PE closed Box 8" paper woofer, shielded. 299-314 NOS woofer NOS
2 Madisound Swan 12" woofer. NOS woofer NOS
2 Madisound NHT 12" woofer. NOS woofer NOS
2 Virtue 6.5" woofer, thk. Front plate. Poly cone. NOS woofer NOS
4 Peerless 6.5" Woofer. PE 264-1088 830657. NOS woofer NOS
2 Vifa 6.5" P17W3-00. NOS woofer NOS
2 Vifa 5" woofer. P13WW-00. NOS. 1 dusty woofer NOS
2 Peerless (NHT) 6.5" woofer. 850397. NOS woofer NOS
1 Vifa BC11BG0706 4.5" woofer. JBL NOS woofer NOS
4 MCM 18" Hvy mag woofer. 55-2959. Slightly used woofer Used
2 PE BR-1 black. 12 Liter cabinets for 6.5" Woofer woofer Used
12 PE DA175-8 7" Aluminum woofer. woofer Used
1 PE Dayton 8" shielded woofer. RS225-8. woofer Used
3 Vifa 10" woofer M26WR-09-08. Cast Frame for SB . woofer Used
2 Peerless 10" woofer, XXL 830452 woofer Used
2 Peerless 8" woofer, 830411. woofer Used
3 Eminence 18" PA Driver. 18341 Wright sound B/O . woofer Used
4 Goldwood 18" PA woofer. GW1858. woofer Used
2 Vifa 8" woofer. P21WO-00 Very used. woofer Used
8 Eminence 12" cast woofer. 121321. 2 need re-cone woofer
2 Eminence 12" Neo woofer 3012LF. woofer
4 PE classic 15" Woofer, DC380-8 woofer
2 Madisound 10" Precision SB woofer 1056-08 woofer
4 Peerless 5.5" Woofer. 299-125. Peerless AULA01213-004 4 woofer
2 Peerless 6.5" woofer, SDS-160F25PR01-08 woofer
2 Tang Band T1-CO-165 1" tweeter, tweeter NIB
4 Seas 27TDFC 1.1" tweeter. tweeter NIB
13 Dali (Vifa) BC25TG19-04 1" S. Dome tweeter. tweeter NIB
2 Peerless 1" Aluminum Dome, DA-25BG08-08. tweeter NIB
2 PE Phenolic Ring Tweeter, 270-250. tweeter NIB
2 PE Euro 1" silk dome 275-100 tweeter NIB
2 PE Euro 1" replacement dome tweeter NIB
2 PE NE25FA-4 1" dome tweeter, Neo tweeter NIB
2 SB Acoustics SB-29RDC-04 Silk dome Tweeter tweeter NIB
2 Scan Speak 1" Aluminum Dome, 2904-9800-001 NOS tweeter NOS
2 Peerless 1" Titanium Dome, H25TG05-08 NOS tweeter NOS
2 Fostex 1" horn tweeter. FT17H NOS tweeter NOS
4 Pyle .75" Auto tweeter, NOS tweeter NOS
1 PE 1-1/8" RS28A Aluminum Dome tweeter. NOS tweeter NOS
4 Peerless 1" Horn Tweeter. 811647. NOS tweeter NOS
2 Scan-Speak D-3806-8200-00 1.5" Twt. tweeter Used
2 Vifa TC9FD-18-08 mid-tweet. tweeter Used
2 Vifa TC9FD-10-04 mid-tweet. (4 ohm) tweeter Used
2 Seas 27TDFC 1.1" tweeter. tweeter Used
2 Scan Speak 1.1" Revelator wave guide Tweeter. tweeter Used
2 Peerless 1" tweeter. 812687 . tweeter Used
2 North Creek 1" tweeter. 2506. tweeter Used
4 PE 1-1/8" Silkie 275-070 tweeter Used
1 Seas H537-06 1" aluminum Dome Tweeter. tweeter Used
2 Vifa BG25TG19-04 1" silk dome tweeter. tweeter Used
2 Vifa BC-25TG15-03 tweeter
2 GRS 1TD1-8 Tweeter tweeter New
2 GRS 1TD2-8 tweeter tweeter New
2 Morel MDT33 matched 1" tweeters. Need diaphragms tweeter
6 Tymphany H26TG45-06 1" horn loaded silk dome twt tweeter
2 Tymphany H25TG05-06 1" horn loaded titanium dome tweeter
1 No name 8" sub-woofer, thick front plate, B/O. Sub-woofer NIB
4 Tang Band W6-1139 S 6.5" Sub woofer, NOS Sub-woofer NOS
4 PE B/O 10" subwoofer. Thick top plate NOS Chinese Sub-woofer NOS
3 Peerless 8" Subwoofer, DVC 831858. Sub-woofer Used
1 Altec 605A or B HF replacement voice coil. 34852 parts
4 Vifa KD-10 cone midrange. B/O NOS New
6 No Name B/O 6" seal back B/O with gasket. NIB NIB
2 Eminence Alpha 6" closed back midrange ACMBR midrange NIB
2 Eminence Alpha 6" Open back midrange. midrange NIB
4 PE Dayton 2" aluminum Dome mid RS 52AN-8 midrange NIB
8 Titan 5" sealed back midrange B/O midrange NIB
8 Hi-V Swan 2" soft dome midrange. NOS midrange NOS
2 Pioneer 5" paper cone midrange w/rear cup. B/O midrange Used
2 Scan Speak 5" Kevlar Mid 13M8638 midrange Used
2 Eminence Beta 10" closed back midrange CBMRA midrange New
9 Vifa TC9FD-18-08 mid-tweet. Mid-tweet NIB
1 Vifa TC9FD-18-16 mid-tweet. (16 ohm) Mid-tweet NIB
4 MCM 8" pressed frame mid-bass. 55-2971. Mid-bass NIB
2 Tang Band W3-2141 full range, full range NIB
2 Tang Band W3-1053 full range, full range NIB
2 Tang Band W3 un-known, full range discontinued full range NIB
2 Tang Band W2-800 SL full range, full range NIB
2 Tang-Band 5" Full RangeW5-2143. full range NIB
8 Aura-Sound NS3-193-8A1 3" full range. full range NIB
4 Onkyo 6" paper full range with wizzer PE 269-745 NOS full range NOS
2 Vifa Neo 4" full range. NE-123-W4 NOS full range NOS
3 Radio Shack 8" full range. 1286C. NOS full range NOS
2 Eminence Beta LT-12" Full range with wizzer full range Used
2 Bose 2" full range salvage. Works! Shielded. full range Used
6 Foundtec 3" full range, aluminum cone FE83 B/O full range New
4 Vifa AP13FG1-04 5" Full range with Wizzer NOS B/O full range NOS
1 Radio Shack 3" full range. Works pretty well actually. full range
1 Behringer CX3400 active crossover. crossover NIB
4 Foster C-D aluminum horn with 1" driver, 025N03 comp driver NIB
2 Eminence ASD-1001 1" compression driver. comp driver NIB
2 Selenium-JBL 1.4" compression driver D220-TI. NOS comp driver NOS
2 Radian 2" Hvy compression Dvr. #4753 (Pano's) comp driver Used
2 PE-Ford B/O 6" X 9" Auto coax, 4 ohm w/CO. coax NIB
1 Radial 12" B/O coax. coax NIB
2 Selenium 15" Coax. 15CO1P. coax Used
2 PE .79 cu. Ft. (22.36L) cherry flat side cabinets cabinet NIB
2 Madisound Woodstyle 25L Lt. Oak cabinets, WS803 cabinet NIB
4 PE Pro knock Down 1.7 cu.ft. oak cabinets 245-325 cabinet NIB
1 Flea tube amp, 1 WPC, Woonster gift, amp NIB
5 PE Lepai 10 WPC Class D int. amp W/PS & Cable. amp NIB
1 Jensen auto sound stereo Amp, 50 WPC. amp NIB
1 Grayson King stereo SS pre amp kit w/o case amp NIB
1 Behringer Xenyx 802 mic pre-amp amp NIB
3 PE Dayton "T" chip amp w/PS & pwr. Cable. amp Used
1 Virtue 2 chip amp w/ pwr. Sply & Cable (Pano gift) amp
2 PE B/O SS JBL amp module. 10 Watt. 329-030 amp
1 RCA-Pioneer 120 wpc stereo receiver amp
1 JVC 75 wpc stereo receiver amp
1 Radio Shack dynamic voice mic. 33-3004 NIB
1 QSL Q 7887 computers sound system. NIB
2 Peerless 10" passive radiators. 830468 Used
1 Audio Technica turntable with cart & software
John Busch
Re: John Busch
By: Pano on Mon, 20 June 2022 07:38
Re: John Busch
Re: John Busch
By: Barryso on Mon, 04 July 2022 18:47
Re: John Busch
By: Pano on Mon, 04 July 2022 19:08
Re: John Busch
Re: John Busch
By: Pano on Tue, 05 July 2022 11:15
Re: John Busch
By: Pano on Fri, 08 July 2022 09:16
Re: John Busch
By: Pano on Fri, 08 July 2022 09:48
Re: John Busch
By: Pano on Fri, 08 July 2022 09:52
Re: John Busch
By: Pano on Fri, 08 July 2022 09:57
Re: John Busch
By: Pano on Fri, 08 July 2022 09:58
Re: John Busch
By: Pano on Fri, 08 July 2022 09:59
Re: John Busch
By: Pano on Fri, 08 July 2022 10:17
Re: John Busch
By: Shane on Fri, 08 July 2022 18:25
Re: John Busch
By: Pano on Fri, 08 July 2022 18:38
Re: John Busch
By: Shane on Fri, 08 July 2022 19:12
Re: John Busch
By: Pano on Fri, 08 July 2022 19:23
Current Time: Fri Nov 06 01:13:51 CST 2026
