Home » Sponsored » Pi Speakers » Small Room Suggestions
Re: Small Room Suggestions [message #95759 is a reply to message #95758] Fri, 01 July 2022 16:31 Go to previous message
All my speakers tend to work well with boundary reinforcement, so half-space or quarter-space is best. Of course, that then gives SBIR but that's what flanking subs mitigate.
Speakers pulled far away from walls always have the benefit of no SBIR, but then they often sound kind of thin. It's always a trade-off of one kind or another.
I personally like placing speakers fairly close to walls and using flanking subs. It is an approach that usually works pretty well.
Of course, most times my smaller models - the one Pi and two Pi speakers - are used without flaking subs for one reason or another. Sometimes, they're used as surrounds, so subs are in the room but not flanking the surrounds. Sometimes, they are used alone in a small room and subs aren't used because the room is cramped for space. Ironically, that's when flanking subs and/or multisubs are most needed, but if there's no room, it's not an option.
Previous Topic: 4 Pi - any "doping" suggestions to make the JBL look nicer?
Next Topic: 2PI Crossover
Current Time: Thu Nov 05 19:26:40 CST 2026
