Re: My 3π adventure [message #95746 is a reply to message #95260] Thu, 30 June 2022 13:27 Go to previous messageGo to previous message
All the cabling is now done. I also masked them with some tape for the painting process as they are going to be professionally spray painted. I am going to the shop tomorrow. There's now light at the end of the tunnel.
/forum/index.php?t=getfile&id=3094&private=0
Looking back at it, it was hard work, much harder than I initially though. Worst part of it is that it requires BOTH heavy and precision work. So you're tired from lifting, tightening etc and then you have to work with mm tolerances. It would be much easier if I just took my time but I really want to listen to them!
Next Topic: 7 Pi plans
Current Time: Sun Nov 08 20:05:33 CST 2026
