Re: My 3π adventure [message #95739 is a reply to message #95260] Tue, 28 June 2022 14:33 Go to previous messageGo to previous message
Funny thing that always happens, problems arise only in the parts that you thought they were easy. I actually had difficulty in mounting the crossover. MDF doesn't take kindly tightening screws, even when the correct pilot hole is being used. I did screw the crossover correctly however because the PCB was bending I could not fully tighten it down. The screws went into the wood around 5mm. I just hope it will hold. I did some stress testing (Very Happy), that is trying to take it of by force but it seemed pretty stable. We'll see how that goes I guess.
The insulation is also done. I hope I did everything correctly. In one of the speakers there is a gap of around 0.5-1.0 cm where the bottom back insulation meets the bracing board. I hope that's ok. The cable you see running is for the de250, obviously. I had the idea to put some duct insulation around it just in case it somehow bangs again anything hard inside.
/forum/index.php?t=getfile&id=3093&private=0
And finally here is a video of the finished pi logos! My friend sent me this I don't have them here. Again, this is platinum plated brass. I am still thinking on how to mount these, I will probably use superglue.
https://youtube.com/shorts/3XT9GZYy36o
  • Attachment: IMG_6204.jpg
    (Size: 1.53MB, Downloaded 1210 times)
Next Topic: 7 Pi plans
Current Time: Tue Oct 20 21:58:34 CDT 2026
