Re: My 3π adventure [message #95724 is a reply to message #95723] Sat, 25 June 2022 20:03 Go to previous messageGo to previous message
Don't panic, because I don't think you've ruined them. But don't force them either. Take the extra effort to go get that tap and use it on each of the T-Nuts. They're super-easy to use - just like threading in a screw - but the tap is hardened steel and has cutting edges that will remove any burrs and put the threads back in place. You'll be glad you did it.
Next Topic: 7 Pi plans
Current Time: Sun Nov 08 20:05:35 CST 2026
