Re: My 3π adventure [message #95723 is a reply to message #95260] Sat, 25 June 2022 19:33 Go to previous messageGo to previous message
I checked again. Unfortunately in 2 of them I cannot turn the screw by hand. Bear in mind that I can completely put the screw in and out with a screwdriver, it just takes a bit of force. So I guess these are damaged.
I will probably try to find a M5 tap here, I am just nervous because I haven't used one before. From what you write I understand that I will probably get away with it without doing anything but what's the bad case scenario? Is that that the screw might get completely misaligned and further destroy the remaining threads?
I did use several sacrificial screws for this. They there SS Allen screws and they were used twice at maximum. I guess I overtightened them.
Next Topic: 7 Pi plans
Current Time: Tue Oct 20 21:58:33 CDT 2026
