Re: My 3π adventure [message #95700 is a reply to message #95698] Wed, 22 June 2022 11:18 Go to previous messageGo to previous message
Looks great!
I empathize with you on the insulation. But you only have to do it once. Smile
As for installing the woofers, I like to lay the cabinets on their backs and gently lower the woofers into position. It's easier to line up the mounting holes that way. Connect the wires beforehand, of course.
I often position the woofer at an angle - with an edge resting on the flush routed groove - and connect the wires. Then rotate it and lower it into position with the mounting holes aligned.
Thread the mounting screws several turns by hand. You want to make sure they aren't cross-threaded. If they are hard to turn - don't force them - investigate, perhaps taking them out and rotating the driver just a little bit to re-align the holes.
Next Topic: 7 Pi plans
Current Time: Sun Nov 08 20:05:36 CST 2026
