Home » Sponsored » Pi Speakers » MDO - Instead of Plywood (Materials)
Re: MDO - Instead of Plywood [message #95617 is a reply to message #95611] Fri, 13 May 2022 13:24 Go to previous messageGo to previous message
iplayforme is currently offline  iplayforme
Well, I guess I better get comfy with MDF. I'll get these together for now and work on it. I have to admit I half-axxed my effort a bit with cutting. Honestly it's been a while since I worked with wood and I tried to cut with a circular saw and then plane the edges true. I just don't want a table saw in the garage. I might try a track setup for the saw and or look at how I can use a router to make perfect edges. Thanks for the replies.
John
Previous Topic: 4Pi - alternate compression driver mounting?
Next Topic: port and insulation
Current Time: Thu Nov 05 18:07:15 CST 2026
