Home » Sponsored » Pi Speakers » room and amp questions
Re: room and amp questions [message #95572 is a reply to message #95571] Sat, 30 April 2022 19:29 Go to previous message
Kits include parts to build one loudspeaker. They include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
As for the upgrade questions, please see the Pi Speakers FAQ, specifically the section called "Models, Upgrades and Driver Characteristics." It has a couple links about options and upgrades that will probably help you decide what you want.
Previous Topic: 6 PI plans Please
Next Topic: 4Pi - alternate compression driver mounting?
Current Time: Mon Nov 23 06:07:53 CST 2026
