Home » Audio » Thermionic Emissions » The Yokes on me
Coupling cap/grid choke, etc. [message #9550 is a reply to message #9548] Tue, 14 February 2006 06:51 Go to previous messageGo to previous message
My grid chokes are 1700H/8k amorphous "C"-core devices. The "Q" of the RCL circuit (choke model - inductor in series with resistor, and paralelled by winding capacitance) is Q=[(L/C)^0,5]/Rw. If we (simplified) observe L as a constant, and Rw=8k constant, too, then we can lower the Q (and avoid subsonic resonance) by enlarging the coupling cap, or by adding external resistance. Series external resistance Rout of the driver "dampens" the Q, and parallel R can also help a bit.
I simply used 4,7µF Mundorf Supreme coupling cap, "good compromise" between the cost/dimensions and value.
In the next couple of days I`ll post about this experiments on "Group Build" forum, but in short:
-E182CC cascode with ~20mA and Ra=15k has output impedance Rout=Ra`=Rin//Ra ~14kOhms. Amplification is A=gm*Ra`, and with gm~4ma/V and very large (infinity) loading impedance (grid choke, Zgch=2Pi*f*L) our amplification is A=4*14=56 times. We can say that we aproach this on high frequencies, say 10kHz, where Zgch=106,8MOhms theoretically and simplified. On larger frequencies, say 20kHz and up, Cw "comes into play" and with Rout of the driver forms low-pass filter. On the lowest frequency of interest, say 20Hz, our Zgch is "just" 213,6kOhms. In parallel with Ra`=14k, we have Ra``=14//213,6 = 13,139kOhms, and amplification is "only" 52,55 times. But, when we express this in dB, it`s a difference of only 0,55dB.
Is this negligible? In my listening tests these days I found that high Rout cascode in combination with grid choke isn`t really the best solution. Sound was bright, and bass was "anemic".
When I used the CCS parallel with Ra, and used Mu-out, then I got the "right" sound, from "bottom to top". Unfortunatelly, I don`t have measuring devices for objective evaluation of the circuit, just the subjective sound" results :-).
I didn`t notice bass boost / subsonic resonances, although Mu-out has low Rout (no ext. damping). As I said, good sound, bass "punch" returnes, and amplification is ~55.
Previous Topic: Another SET Forum You May Not Know About
Next Topic: New headphone amp.
Current Time: Thu Nov 05 04:01:49 CST 2026
