Home » Audio » Source » Safe to play?
Re: Safe to play? [message #95462 is a reply to message #95461] Fri, 01 April 2022 20:14 Go to previous messageGo to previous message
From what you've shared, it looks like you have more than one tape. I think you should try to play one of them. If it works, great. If not, then you can send the mangled tape off with the others to see if the recordings can be salvaged. Play it loud enough that you can record it digitally at the same time. There's probably a machine that will do that for you, but I've never run across one.
Previous Topic: Saved On Vinyl
Next Topic: Radial Audio Stealth One Tonearm by Dean Slindee
Current Time: Tue Nov 03 10:21:12 CST 2026
