Home » Sponsored » Pi Speakers » 12pi bass horn plans
Re: 12pi bass horn plans [message #95236 is a reply to message #63735] Fri, 11 February 2022 08:23 Go to previous messageGo to previous message
Apade is currently offline  Apade
Hello there!
Love the design and the cooling method! I want to build up to four pieces of the 12Pi but since I am located in Germany, I am not able to get flat packs, the woofers or even the cooling parts from you (shipping would cost a thousand $ more than four times 12Pi Kit with cooling parts! Confused ) so I will have to machine the parts myself...
I am a bit anxious about drilling the pole vent of the woofers, since I don't want to get metal to fall behind the dustcap and into the magnetic gap... Is there a trick to prevent metal from falling inside the woofer?
Is it possible to get the Plans from you and some more detailed drawings of the cooling plug? The drawings I got do not state the length of the upper (wider) part of the plug. Also 3d files of the cabinet and the cooling plug would be much appreciated so I can convert to *.dxf and give it to my local CNC guy!
Thanks in advance and greetings from Germany -
Previous Topic: Optional Drivers and Upgrades
Next Topic: Recessed baffle and speaker grills
Current Time: Sun Nov 08 00:23:41 CST 2026
