Home » Sponsored » Pi Speakers » Pi Horn makes weird noise. (When the plate of 1 is on or off )
Re: Pi Horn makes weird noise. [message #95177 is a reply to message #95176] Thu, 03 February 2022 14:07 Go to previous message
The drivers are run push-pull, so one side is reverse-connected. Make sure that you do this.
If you've connected it wrong, it will actually be louder with one driver disconnected.
So try to reverse-connect one of the drivers and see if that helps. Specifically, reverse-connect the driver that energizes the throat of the horn from the basket side of the cone.
Previous Topic: Three Pi Sub Plans
Next Topic: Optional Drivers and Upgrades
Current Time: Wed Nov 18 01:26:00 CST 2026
