Home » Sponsored » Pi Speakers » 4Pi - alternate compression driver mounting?
Re: 4Pi - alternate compression driver mounting? [message #95159 is a reply to message #95157] Mon, 31 January 2022 15:00 Go to previous messageGo to previous message
I would strongly suggest adding insulation first. Especially the cross-section sheet. Try it straight. Try it diagonal. Make sure you can mitigate that peak at 120Hz.
I say this because you might find that your efforts to damp the peak are illusive, and you might end up moving the port. This is best learned while you're still in the "cut and try" mode.
Previous Topic: room and amp questions
Next Topic: MDO - Instead of Plywood
Current Time: Thu Nov 19 10:30:29 CST 2026
