Home » Audio » Source » Wide Spread RIAA Phono Stage Inaccuracies by Manufacturers (Inaccurate RIAA designs and correct calculator.)
Re: Wide Spread RIAA Phono Stage Inaccuracies by Manufacturers [message #95107 is a reply to message #95105] Sat, 22 January 2022 23:27 Go to previous messageGo to previous message
Strum Drum wrote on Sat, 22 January 2022 19:22
What's the reason behind the inaccuracies, though? I read the article and couldn't find the reason that so many models are like this. I saw this bit, - "These errors are due in part to the perpetuation in print of incorrect formulas for the design of the RIAA equalization networks commonly employed." However, I don't understand why it was an issue in the first place. I'm not an engineer, but I just assumed there was a standard that everyone followed.
What Stanley is stating is that the design equations used by the designers/engineers are not correct. It is one thing to calculate a single pole complex math problem, but when multiple poles are needed, very complex math is needed. The designers/engineers did not understand how to perform the correct math.
I surmised that there are equations in general, standard reference, use that are incorrect and were simply copied by many designers/engineers.
Hope this helps. Cheers.
pos
Previous Topic: The Intellectual People Podcast - Orchard Audio
Next Topic: What happened with wire recorders?
Current Time: Fri Oct 02 10:35:46 CDT 2026
