| Re: Really Tweaking The EQ. [message #94977 is a reply to message #94967] |
Mon, 20 December 2021 20:39  |
gofar99
Messages: 2063 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, Not exactly...however something like the Behringer DEQ2496 I have will allow you to store a bunch of eq curves. So all you would need to do is select the one you want for each type of music. It allows you to label each curve so there would not be a lot of confusion. The down side is the units are not cheap and will need to be inserted into the signal chain. Usually this is between the preamp stages and power output ones. So...if you use anything but a serious stereo system this option won't work for you.
