Home » Audio » Thermionic Emissions » is ok to put a tube PRE in front of SS amp?
Re: There is a simple solution to the problem [message #9475 is a reply to message #9474] Fri, 30 December 2005 07:07 Go to previous messageGo to previous message
Hey-Hey!!!,
My first foray into a valve pre was quite similar to the foreplay circuit. I added the bipolar supply, and increased the CF tail load. It was running more current, and through a larger resistance. Adding a CCS there made little if any improvement.
The shorting switch for the output is easy, a DPST will do quite well, and eliminated the risk of a large transient.
With VR tubes, a CCS instead of a resistor to feed the VR tube has always worked better for me. Less of a need for a high raw voltage( like the 2x regulated that is suggested ).
While you're building CCS-es, build two more for the plate loads, and do away with the CF stage. The mu-follower output from the MOSFET CCS is going to have lower output Z than most CF's anyway, and it eliminates the need for that extra stage.
cheers,
Douglas
Previous Topic: NOS Tubes Picture Library to ID tubes
Next Topic: New tungsols from SRS tubes and hickock results
Current Time: Tue Oct 20 14:52:44 CDT 2026
