Home » Audio » Thermionic Emissions » Pinging MQracing
Re: SE - Copper would be cool! [message #9463 is a reply to message #9454] Fri, 23 December 2005 20:44 Go to previous messageGo to previous message
2wo is currently offline  2wo
While the plastic experts are here, a little help.
I an looking to make an adjustable head for a spotting scope and I need a recommendation for material.
I need a 3"x4"x4" or so hunk of plastic. I have seen a gray industrial material that I think wound be perfect but I don’t know what it is.
I need to ‘machine’ this on my drill press with not much more then an end mill and a cheep X,Y table
A fairly hard non slippery plastic that I can tap to say , ¼ 20 without cracking (with due care)
I think plexiglass may be too prone to cracking, nylon may be too soft Delrin would be OK but this will need to clamp to a ¾ or 1" shaft and stay put. May still be OK but I wish I knew what the gray stuff is
Thanks in advance for your help…John
Previous Topic: New Millett Hybrid Done!
Next Topic: Douglas, Damir, I did some more work on the 300bPP amps
Current Time: Tue Nov 03 06:12:28 CST 2026
