Home » Audio » Thermionic Emissions » Pinging MQracing
SE - Copper would be cool! [message #9449 is a reply to message #9447] Wed, 21 December 2005 21:10 Go to previous messageGo to previous message
I thought you said in an earlier post about welding plastic... but I wasn't sure. Is that done simply with heat? Can you get really smooth seams?
I've never seen smooth seams when plastic welding. It's basically just a small diameter heat gun used to melt plastic rod that is fed into the seam.
SE --- Copper would be cool!
Previous Topic: New Millett Hybrid Done!
Next Topic: Douglas, Damir, I did some more work on the 300bPP amps
Current Time: Tue Nov 03 06:12:43 CST 2026
