Re: 4pi build with stands finally realized [message #94425 is a reply to message #94424] Tue, 14 September 2021 04:15 Go to previous messageGo to previous message
Horn mounting. Tight fit, and flush. Made two extra holes on the sides of the horn just to be sure. The horn itself is damped too.
/forum/index.php?t=getfile&id=2836&private=0
Filter install. Just enough place for the filter. Speakon 4 pole installed on bottom. I modified the filter for bi-amping to have the option. With four wires in it is also possible to test active crossover and dsp if/when I get the urge.
/forum/index.php?t=getfile&id=2837&private=0
2 inches fiberglass insulation mounted under top brace.
/forum/index.php?t=getfile&id=2838&private=0
Speakers had to be bolted to the stands before filter/woofer install. Four bolts with rubber gasket between stand and speaker.
/forum/index.php?t=getfile&id=2839&private=0
Current Time: Tue Sep 29 21:22:19 CDT 2026
