Home » Audio » General » When to recap?
Re: When to recap? [message #94338 is a reply to message #94337] Tue, 31 August 2021 21:42 Go to previous messageGo to previous message
Hi, I tend to agree...but in all the time I have been using gear (mostly Marantz) or designing my own I have never had a cap go so far out of wack that I needed to replace it. I suspect it partly comes from having high quality gear and using only similar stuff in my designs. I am sure that budget caps are more likely to fail. A problem I have run into in some folks diy builds using tubes is to use 85C rated electrolytics. Only 105C ones ought to be used and they should be placed away from. heat sources. I get a chuckle out of a lot of vintage gear with "can" caps placed right next to power tubes. A guaranteed way to cause problems. Confused
Previous Topic: YouTube to Mp3
Next Topic: home depot Husky heavy duty steel shelving for your audio
Current Time: Sun Nov 01 03:26:47 CST 2026
