Home » Audio » Source » Digital Recorders Price Range and Quality
Re: Digital Recorders Price Range and Quality [message #94227 is a reply to message #94207] Sat, 14 August 2021 21:15 Go to previous messageGo to previous message
Hi, I believe you will find that both are true. Features can be important particularly on the input side. Things like sample rates and types of files generated are IMO very important. A recorder that only does 44K at 16 bits and converts the output to MP3 files is IMO useless. I personally don't use anything below 96K/24bit with uncompressed output files. I generally use .wav files even though they are large. Other loss less outputs are fine as well. But with storage space so cheap now I like the long term compatibility of .wav. Just this week I saw a 2TB drive for $55. How can you go wrong at that cost?
Previous Topic: Which wire is used in Linn T-Kable (tonearm cable for Linn Akito tonearm)?
Next Topic: The Intellectual People Podcast - Geshelli Labs
Current Time: Thu Nov 12 04:12:03 CST 2026
