Home » Audio » Thermionic Emissions » new arrival
Thanks Damir [message #9402 is a reply to message #9400] Fri, 09 December 2005 11:24 Go to previous message
Tre' is currently offline  Tre'
They are really just the output stages. The left and right front ends (paralleled 6sn7, SS CCS loaded, cap coupled to a center tapped, phase inverting, grid choke) are on a third chassis with a LCLC power supply for the front end on a forth. The 300b's are running 72ma. cathode biased with 360VDC across the tube. I will be increasing the current in the output tubes slowly until I find that sweet spot. The output stage supply is 5u4 10HY 20uf (oil) 2.5Hy 40uf (oil)
Tre'
Previous Topic: 12B4 data?
Next Topic: Holliday issue of DIYMAG ezine now available online
Current Time: Fri Nov 13 15:34:45 CST 2026
