Home » Sponsored » Pi Speakers » four Pi and subs
Re: four Pi and subs [message #93770 is a reply to message #93769] Sat, 15 May 2021 10:16 Go to previous messageGo to previous message
Jetpump is currently offline  Jetpump
Wayne Parham wrote on Tue, 19 May 2020 15:59
The woofer and tweeter are direct replacements, and they can be exchanged through the front of the baffle. The cabinet stays the same.
There are some crossover changes required, but they are inexpensive and pretty easy to do. Some resistor values are different for the DE250 because it has slightly higher voltage sensitivity than the PSD2002. You can see the components used for each option in the "Notes" section of the crossover document.
Here are some of my thoughts about the upgrades available:
For different compression drivers, is it only resistor swaps? I guess I'm wondering if the horn dictates the frequency response vs. the driver for crossover design.
Thanks,
Billy
Previous Topic: 1pi port and insulation
Next Topic: Amp Camp Amp
Current Time: Thu Nov 19 04:40:41 CST 2026
