Home » Audio » Thermionic Emissions » Some questions on Power supplies
Re: Some questions on Power supplies [message #9374 is a reply to message #9370] Mon, 28 November 2005 14:39 Go to previous messageGo to previous message
2wo is currently offline  2wo
I think you can get the 750VCT transformer to work. If your not dead set on a choke input filter.
Go back to the example that Damir posted.(how do you do that?) Change the transformer voltage to 275, then tinker with the value of the first cap. As you slowly increase the value, the output voltage will rise.
With 10uf I was able to get ~365with 5Y3’s 10uf- 10h- 50uf With a 70ma CS...John
Previous Topic: Anyone know how bad this is?
Next Topic: Transformer specs
Current Time: Sun Sep 20 11:32:54 CDT 2026
