Home » Audio » Room Acoustics » Is it safe to position a Sub facing a room's side walls?
Re: Is it safe to position a Sub facing a room's side walls? [message #93715 is a reply to message #93714] Tue, 11 May 2021 13:35 Go to previous messageGo to previous message
If you really crank those subs up, the airflow through the ports will increase and things nearby might cause an obstruction. But if you're not really pushing them hard, airspeed won't get high enough to matter.
Put a sheet of cardboard where your nearest obstruction is. If the cardboard flutters from port airflow, then consider moving the obstruction. If it doesn't, don't worry about it.
Previous Topic: Same stereo/speakers different sound
Next Topic: Biggest waste of money?
Current Time: Thu Nov 12 06:00:46 CST 2026
