Home » Audio » Thermionic Emissions » Transformer specs
On the other hand... [message #9368 is a reply to message #9360] Sun, 27 November 2005 15:16 Go to previous messageGo to previous message
2wo is currently offline  2wo
I took a look at the schematic you linked and you may be able to run say four 6L6’s.
This will depend on a couple things. First are you planing to try to use the existing output transformers?
A push pull, pair of 6V6 is usually used with transformer input impedance of about 10K or so. With parallel
6v6’s it is probably 5k or so.
Another thing this is actually two amps and this is low end so how this transformer will work full range is an open question.
Let’s start with that…John
Previous Topic: Some questions on Power supplies
Next Topic: Say Douglas; Hows the Mods coming along?
Current Time: Fri Sep 25 00:17:24 CDT 2026
