Home » Audio » Thermionic Emissions » Some questions on Power supplies
Re: Some questions on Power supplies [message #9367 is a reply to message #9365] Sun, 27 November 2005 14:56 Go to previous messageGo to previous message
2wo is currently offline  2wo
Hi Guy, if you know what the AC output of transformers that you have, you can go right to Psu2 and cut and try.
Measure the DC resistance per Damir. Or just using the dc resistance of the secondary will be close enough to tell if the transformer could work.
As a rule a choke input filter will give you about .7 of the rated voltage cap input about 1.4
Remember if you have say a 250-0-250 transformer, in Psu2 with a full wave rectifier (normal hook up for a 5y3) you state the transformer as 250V.
If you can’t get a high enough voltage, switch to a full wave bridge (SS or tube) and try again. Only in this configuration, you state the above transformer as 500V
Have fun…John
Previous Topic: Anyone know how bad this is?
Next Topic: Transformer specs
Current Time: Sat Oct 31 11:51:54 CDT 2026
