Home » Audio » Thermionic Emissions » Worth my while?
Re: Worth my while? [message #9343 is a reply to message #9342] Sun, 20 November 2005 04:10 Go to previous messageGo to previous message
Good price, but 42VA and 55mA DC (with cap input) are not much, and 385-390V DC specification is a little strange to me (no AC secondary voltage given) - that probably means that you can expect this voltage/current after rectification? We need to know AC secondary voltage (probably about 300V AC if 390V DC is specified). You`d need 250-300V DC "through" the tube, and 45-65V "through" cathode resistor tipically for 2A3, and about 10-15V voltage drop through the OPT primary winding resistance. It can work like SS diodes "bridge" rectifier, with small, "tuning" input cap to get voltage you need, then LC filter. With full specs (secondary AC voltage, primary and secondary resistances), you can model the PS with "Duncan PSU II" program.
For the other, "off the shelf parts" you`d need two output transformers, say Hammond 125ESE (~$36 each), two chokes, tubes and other mechanical and electrical parts.
If you choose to build this project and have some additional questions, try "Group Build" forum.
Previous Topic: needing to find a reliable source for tubes
Next Topic: simplifying the Guinevere
Current Time: Sat Oct 31 06:23:01 CDT 2026
