Home » Sponsored » Pi Speakers » Aztec Monet Cabinets
Re: Aztec Monet Cabinets [message #93309 is a reply to message #93293] Thu, 11 March 2021 15:45 Go to previous messageGo to previous message
Just one more thought... If you are up for replacing the baffle board for a 4-Pi replacement design, you can always fill the insides with rigid foam board to take up the excess volume, so the boxes are a bit over-sized, but the actual inside volume and maybe even dimensions would match Wayne's specs. I've done this before, and it seemed to work fine. Of course, the regular insulation would go over the foam board.
Chris
Previous Topic: long wall setup
Next Topic: 8Pi Midhorn fabrication
Current Time: Mon Oct 12 16:12:06 CDT 2026
