Wayne Parham Messages: 19105 Registered: January 2001
If you want, I can reset the password for your old account and then you can login and set it to whatever you want it to be.
As for the radial H290 horns, it sounds to me like you may have gotten them from different batches. They were all pretty much the same, but I did notice over the years that the texture and color would change from time to time. Seems like the mounting plate area was slightly different at one point too.
But it's probably going to be hard to find those old horns. You might check Ebay.
