Home » Audio » Room Acoustics » Sound-proofing advice?
Re: Sound-proofing advice? [message #93144 is a reply to message #92837] Tue, 16 February 2021 14:28 Go to previous messageGo to previous message
Raymond is currently offline  Raymond
PinkHair wrote on Mon, 21 December 2020 21:20
You could also buy a pad to put under a rug that you're adding, or that you might already have in the room. They're pretty inexpensive. I found one on Amazon for under forty dollars.
Here's an example of one
https://www.amazon.com/Mohawk-Home-Surface-Hardwood-Surfaces/dp/B007T58N80/ref=sr_1_5?dchild=1&keywords=soundproofing+under+rug+pads&qid=1608607133&sr=8-5
I didn't know that these pads existed! They look like a good option to keep your sound-proofing discreet (unlike my room divider suggestion). I might look into getting some of these!
Previous Topic: What's the main of main of acoustic treatment?
Next Topic: Positioning to mask sound
Current Time: Sun Nov 29 18:36:07 CST 2026
