Wayne Parham Messages: 19099 Registered: January 2001
The seven Pi model is two feet wide due to the midhorn. And while I appreciate the matter of size - if it doesn't fit, it doesn't fit - there is also the issue of feasibility and whether or not the corners and room dimensions are suitable for constant-directivity cornerhorns.
I'm glad you're researching this. I'll bet you're going to put together an excellent system!
